EF Distributor - Did I fried anything?
Old Jun 21, 2016 | 10:59 AM
apm's Avatar
apm
Default EF Distributor - Did I fried anything?
I was troubleshooting my no start on my EF Si civic. I replaced dizzy coil and igniter, tested it and producing spark a day before. I put everything together and trying to start it altogether.
Now I have no spark again. I swapped 3 different coils and igniter and control module also. As well as 2 different dizzy housing.
Did I fried anything when it gave me spark the other day when testing? I put a screw driver on the Coil to test for spark. Unless all of my test parts in the dizzy are all bad, Im starting to think it might be the ECU.
Old Jun 21, 2016 | 11:58 AM
BLU CIVIC's Avatar
Track Advocate
Default Re: EF Distributor - Did I fried anything?
Did you check your fuses?
Old Jun 21, 2016 | 03:10 PM
apm's Avatar
apm
Yes fuses are all good, except for the fuel pump which I took out to minimize fuel during testing of spark.
Old Jun 22, 2016 | 03:59 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Before trouble shooting anything electrical I make sure all grounds are good and clean.
Take the screws off and wire wheel them, sand paper the area where they make contact. Remove all signs of corrosion around the grounds then begin looking for the problem.
Old Jun 22, 2016 | 09:44 AM
fcm's Avatar
fcm
Old Fart
Check for power on IGP 1&2 at the ECU, with ign. switch in run AND start. 94
Old Jun 22, 2016 | 08:22 PM
apm's Avatar
apm
Thanks everyone for the tips...I bought power probe and check pulse on yellow/green wire from ECU to dizzy and i'm not getting any light. From youtube videos, it said that yellow/green wire from ECU to dizzy should give pulse, when I'm starting it.
I will check Ignition pin 1&2 coming from ECU. I'm starting to think I fried the ECU itself when spark was working few days ago and testing it with bare screw on coil for spark.
Old Jun 23, 2016 | 07:12 PM
apm's Avatar
apm
Finally got it! It's the ICM and also the immobilizer from PO. Runs great now and always run on first click!
Ed_dog
21
May 20, 2012 06:09 PM
Nooch
11
Jan 21, 2011 10:22 AM
KRIS05VVTi
13
May 17, 2010 02:26 PM
1990civichatchie
Sep 16, 2006 01:39 PM
aaronhume
27
Apr 7, 2005 02:49 PM
