Ex/Si brake upgrade on a CX hatch question
I bought a front and read disc brake setup from a Canadian '00 civic SiR for my '00 CX hatch. I noticed that the SiR dics brakes had ABS on it which i don't need. Can i install the brakes without connecting the ABS since the CX models never came with ABS?
The Canadian SiR is the equivalent to a US Si
Yes, simply remove the ABS sensors and don't worry about the tone rings on the rear hubs. Your prop valve is already the same as '99 - '00 Si, the only other thing that should be changed is the master cylinder. Find one from a '99 - '00 USDM Si or EX without ABS.
Jonathan_ED3
Mar 24, 2004 04:51 AM
RedlineJunkieH22A
Feb 13, 2003 07:12 PM
