Help. Won't start after running
Old Jun 17, 2016 | 05:33 PM
Rob Holmes's Avatar
Default Help. Won't start after running
I have a 96 accord ex with a 2.2L non V-tech. I can start and drive the car without issue. Runs fine and idles fine. Turn it off and it will not start back up. Eventually it will start up fine and run. I have replaced the fuel injectors and run fuel injector cleaner. Not sure where to go from here. Any advice will be most welcome.
Old Jun 17, 2016 | 09:45 PM
StokelesS_g2's Avatar
Default Re: Help. Won't start after running
Search "ECT" or "Main Relay".
And did someone swap out the VTEC motor?
Old Jun 18, 2016 | 05:15 AM
Rob Holmes's Avatar
Thanks for the info. I have changed the main relay already. I will check the ECT, and the motor is original.
Old Jun 18, 2016 | 07:34 AM
Ya sure you dont have a LX then?
Old Jun 18, 2016 | 01:49 PM
GhostAccord's Avatar
I am going to assume that it is a Canadian chassis EX...... The Canadian CD Accord w/VTEC is an Ex-R
Where it is OBDII, do you have access to an OBD scanner? That would really help you out if it has live data capabilities. So many curse the OBD, but it can tell you a lot about what the engine is doing and what sensors might be a bit off.
Old Jun 19, 2016 | 07:48 PM
93redcb7's Avatar
i had this problem with a bad cap/rotor, after running it and stopping and letting it sit for a little bit it starts to heat soak and plastic expands when it gets hot so it wasn't making good contact(atleast this is what the conclusion i came to because it stopped after i replaced those)
greenwave12
Jun 27, 2015 06:51 AM
Giantsfan2012
Sep 20, 2014 10:49 AM
bcedkin
Oct 2, 2013 10:34 PM
rvanders37
Aug 3, 2005 10:51 AM
misr
Apr 22, 2005 03:18 AM
