GA 1996 Honda Civic Ex- Track ready- Fresh paint
Honda-Tech Member formally known as TomsEF
Engine has around 315,000 I would say. No rebuild needed. The cluster was swapped out for an Si unit and states 147,XXX. I have a 3" stack of every record from new purchase for this car. The original owner took great care of the car and shows by the record keeping. I have driven this car from Chicago to Atlanta, 11+ hrs straight, with not a single issue. Doesn't smoke. Gets great MPGs and anyone that knows this car, knows its solid. Everything works as it should.
Power Steering, AC, Heat, Cruise Control, everything works as it should.
Updated pictures. prior to Si gauge cluster install and new OEM black floor mats.
**Does not come with J's Racing shift **** and extender not included.
Rear trailing arm bushings are OEM. The rest of the bushings are hardrace. Zero rust locked bolts. Every bolt will come out no issues at all. Car has zero rust.
ticklemeermuel
Jan 4, 2013 04:09 PM
