Honda S2000 Honda S2000
S2000 suspension parts
Old Jun 13, 2016 | 03:40 PM
cricketracer's Avatar
Default S2000 suspension parts
Recently bought an S2000 that has had less than "loving" care. The car had aftermarket (Moda) wheels and had a slight pull to the left. After some inspection I found the left front tie rod all the way in, but the car still had a slight pull to the left. After further inspection I found the left front wheel about 5/8 inch further back than the right. Even more inspection showed the left lower control arm bent. (Lots of measurements give me comfort it is not a frame or subframe issue.)
So, looking for thoughts on replacement. Options are used, Honda OEM, or New Aftermarket. Any experience out there with the new aftermarket options? Also, if I go used, i'm looking at bushing replacements. Any opinions on manufacturers?
Old Jul 8, 2016 | 07:47 AM
Bear79's Avatar
Default Re: S2000 suspension parts
I would think Moog would have a control arms for your S2000. Look at this link to see what is available: http://http://www.aftermarketsuspensionparts.com/ If you have any questions give them a call.
shrykhar
Jun 25, 2016 12:23 PM
amalby
Sep 12, 2008 06:05 AM
1C9R9X3
Honda S2000
Jan 12, 2007 04:28 PM
NicoSommer
Honda S2000
23
Dec 8, 2005 10:52 PM
Ricky26500
Honda S2000
35
Sep 1, 2005 09:52 PM
