2000 b16 head cam cap - bolt size?
I have a cam cap bolt or two that I need to heli coil because someone that had the motor striped it out when re-built motor need to know the bolt size to get the right helicoil
The bolts on the end caps with the 10mm heads on them are 6mm x 1.0 pitch size... all of the remaining bolts have a 12mm head and are sized at 8mm x 1.25 pitch.
paopao
Nov 12, 2005 06:07 PM
