Honda CR-V & Element 2WD & 4WD Element & CR-V
2001 CRV - A/C work sometimes.
Old Jun 10, 2016 | 09:49 AM
TheMeanFarmer's Avatar
Default 2001 CRV - A/C work sometimes.
The A/C in my 2001 CRV 5 speed manual will work when the engine is at idle only. On 5% of my travels the A/C works normally and doesn't cut out but most of the time only at idle to I get cold air.
If I am at a stop light, coasting down a hill with the car out of gear, etc... it blows cold and strong. But when I engage the engine in nearly any capacity the A/C instantly blows warm air until the engine is disengaged.
Research leads me to a Pressure Switch but I don't really know if that is what I should try (or even where it is )
Any suggestions?
Old Jun 10, 2016 | 09:34 PM
RS Design's Avatar
Default Re: 2001 CRV - A/C work sometimes.
to me it sounds more like the compressor is over heating.. too much freon/oil .. get that checked first if its at the proper level first before you try replacing the switch which will need to be evacuated first
Gabriel Ale
Dec 23, 2018 06:29 PM
91ef-si
15
Feb 26, 2011 03:15 PM
Ritter57
May 25, 2008 10:01 AM
Mikes2000civicsi
Jan 28, 2007 07:08 PM
matt_in_sd
Apr 3, 2006 07:50 PM
