Transmission & Drivetrain Gearboxes, Differentials, Clutches
DTC reset, HDS tool, and PCM Idle Learn Procedure?
Old Jun 6, 2016 | 04:17 PM
epare's Avatar
Default DTC reset, HDS tool, and PCM Idle Learn Procedure?
My 1999-2004 Odyssey Service Manual, page 11-202, "PCM Idle Learn Procedure", contains a "Note: Clearing DTCs with the HDS does not require you to do the idle learn procedure."
Apparently, Honda dealers use an HDS (Honda Diagnostic System, made by/for Honda?) that will reset PCM DTCs, without the technician subsequently having to perform the idle learn procedure.
Are there any relatively inexpensive, 3rd-party, HDS (Honda Diagnostic System) tools that will reset PCM DTC codes without me having to subsequently perform the idle learn procedure?
I've asked a number of resellers from China this question with regard to the HSD tool shown at New Him for Honda Diagnostic System Tool HDS PC Scan Tool Acura Testers | eBay ; but, they don't directly answer the question. They simply repeat the capabilities shown in their description of the product; and, I'm not sufficiently knowledgeable of those capabilities to be able to answer my question.
Thanks.
Gurnee Matt
Honda CR-V & Element
Apr 16, 2018 03:07 AM
epare
Jun 6, 2016 08:49 AM
90BeAsTJdM
13
Jan 12, 2012 04:39 AM
Lip
Aug 22, 2006 03:54 PM
