Re: EBC w/ S300 having weird problems with Smanager
Yes I'm using Q20 on the other end of the board. It also looks fine.
I posted on Hondata's forum and Spunkster said I need to swap out the non resistor spark plugs for resistor type and only use resistor type. I went to #8 plugs from NGK but the V power are R series. I can't find a #8 plug from NGK that is resistor type so I think I will go back to #7 plugs.
That's not the problem, actually you can enable the EBC when your car is idling. Hook a led and a resistor to A11 and +12v and check if it works. Use this parameters, the led must go on
Any particular size resistor and LED? Can I get those items at say a radio shack or similar?
I can hear that the ECU does control the solenoid. I can change settings and hear it clicking but I can't get it to buzz as if it's working.
From what I red the solenoid should have started to activate and it did not. When I click the normally open or closed tabs I can hear the solenoid click over.
Originally Posted by Spunkster
Just use the test function in the online menu.
Ok.
I just did that test and the solenoid started working but I could not turn it off. My computer disconnected from Smanager and can't connect when the valve is working. Now whenever I turn on the power in the car, the solenoid is buzzing and I can't connect my computer. If I kill power to the solenoid I can hook up to Smanager fine. The problem is only there when the solenoid is activated.
