1990 electrical issues
Old May 30, 2016 | 10:10 AM
Efnino's Avatar
Default 1990 electrical issues
Hey people I have my 1990 Honda std I've replaced the dash harness and the engine harness and my batter still dies after sitting for about 2-3 days. Well I borrowed a snap on voltage meter my battery has 12.6 volts. what should be on while the car is off ?
Old May 30, 2016 | 09:14 PM
Caleb Jankovsky's Avatar
Default Re: 1990 electrical issues
you might be better off hooking it up to check amp draw. Check this out. How to Find and Stop Car Battery Drains ? DIY Car Battery Drain
Old May 31, 2016 | 11:06 AM
fcm's Avatar
fcm
Old Fart
A parasitic drain test with a 12V test light, [NOT LED type], disconnect the batt. neg. cable, connect test light ground clip to the batt. post, then connect test light probe to cable clamp, [series connection] if the test light lights up, you have a parasitic draw, start pulling fuses one by one until test light goes out, when it does you have found the circuit that is drawing power, find the loads on that circuit and disconnect them one by one until test light goes out again.
Replace defective part, your done. 94
fcm
Sep 11, 2020 12:20 PM
David Guevara
25
Apr 23, 2016 07:38 AM
VegaS10
Oct 9, 2011 06:54 AM
Jediracer
Aug 7, 2010 05:54 PM
civic_driver09a
Audio / Security / Video
25
Nov 16, 2009 11:41 AM
