2003 Honda occasionally won't start when engine hot
We are having some trouble with our 2003 CR-V LX/4WD AT. It has 240,000 miles, and I really want to get to 300,000. But we have an issue during summertime months where it won't start after sitting at the grocery store or gas station for 5-10 minutes. Battery and starter are fine. It seems that when the engine is hot, starting is intermittent. My wife reports an "odor" sometimes when this happens (which I am guessing is fuel) but I have never had this happen to me, so no clue. Any ideas?
You're going to recieve a variety of suggestions given the lack of maintenance history you provided.
Google: general problems surrounding no start conditions for cars. Eric the car guy is entertaining http://www.ericthecarguy.com/faq/solving-automotive-no-start-problem
Only you know how the car was maintained. Maybe its simply time for a tune up.
Pull the plugs after this happens. Are they saturated in gas? The fuel smell probably means yes. Which would mean you have gas but no fire. So it could be a weak spark, or no air. Is your air filter dirty?
240k is a lot of miles. Your injectors probably need a good cleaning.
You see where this is going right? May be this, or that.
Could be a temperature sensor issue.
I have had that issue. When the engine is cool I had no problem starting. Go for a quick stop to the gas station and it chugged and chugged to get started.
Coolant Temperature Sensor was bad. With a hot engine it was flooding the engine with gas and it was hard to start.
Bought a new sensor, took off the distributer, swapped the new part in and haven't had a hard start since. (2001 model)
Thomas Larsen
14
Mar 9, 2018 09:06 AM
Brandon Dawson
May 23, 2017 03:32 PM
