2000 CRV Shift lock problems
I have a 2000 CRV with shift lock problems. The shift lock was the first symptom. So I checked the horn fuse and it was blown, so I replaced it. After I released the shifter using the key hole on the steering column and started the car again, the fuse blew again. So I replaced the horn relay and brake light switch with no luck. Also, brake lights are not working. Any ideas?
Thank you!!
Thank you!!
EK9ED
Sep 28, 2012 08:51 AM
