Suspension & Brakes Theory, alignment, spring rates....
asking for advice on power vs non power brakes
Old May 28, 2016 | 09:33 AM
austenjanzen's Avatar
Default asking for advice on power vs non power brakes
I am building my car for 85% track use, auto x and drag strip
and the odd daily driving
Now my question is would you delete the brake booster?
I asked this a few years back and was told not for daily driving, but my crx will be more focused on track use only and the odd driving in the city
What are some pros and cons?
1988 Crx rhd jdm
With b18c type r going in!
Thanks
Old May 31, 2016 | 10:14 PM
chargeR's Avatar
Default Re: asking for advice on power vs non power brakes
You can delete the brake booster and still have acceptable pedal effort, provided you adjust the brake pedal ratio and master cylinder diameter to suit. A typical non-assisted brake system pedal ratio is about 6:1, whereas a boosted system will have closer to 4:1. You'll also typically want to go down a size in master cylinder diameter compared to what you would use with a booster.
I've done it on non-Hondas for track use and with the right changes the drivers of those cars have been very happy.
Old Jun 1, 2016 | 02:45 PM
Okay yeah I was planning on going with some sort of wilwood for the cylinder like most tucked systems and how do you adjust the pedal
Old Jun 1, 2016 | 09:42 PM
chargeR's Avatar
You need to modify the pedal, and the master cylinder must be moved upward to suit. See here: https://honda-tech.com/acura-integra.../#post50377929
ribal_gh
11
Apr 30, 2013 04:24 AM
bambam
15
Jun 20, 2005 06:14 AM
Un0Turb0-WP
Oct 18, 2004 02:14 PM
ryan12321
15
Apr 11, 2004 10:46 PM
Eggman
Oct 6, 2002 09:32 AM
