Mid-Atlantic (Sales) VA, DC, and MD
Race car sfwd ek civic turbo car part out 760+hp. Due to accident
Old May 25, 2016 | 07:14 PM
94eg5squadMD's Avatar
Default Race car sfwd ek civic turbo car part out 760+hp. Due to accident
Racecar part out, full blown , borg, hondata etc. updated post alot left still
tons of parts off my car after a terrible accident
I have had a big post up on this page the past 2 weeks and sold a lot of stuff. Now this a new one with what's left and also some other stuff I decided to sell. Look at pics and the entire ad please
IF YOU DO NOT SEE A PART ON THIS LIST BUT IT IS IN THE PICTURES THEN THAT MEANS IT HAS SOLD ALREADY. ONLY HAVE WHATS IN THE LIST BELOW.
Will update every 24 hours with new pricing and parts that sold or are available
For the most part I would prefer local pick up here in Baltimore md 21222 where I live. but I will ship if you pay shipping and materials and PayPal fee
A lot of this stuff has less then 5000 miles. Car was just built December of 2015 till 2 weeks ago when it was totaled
Thanks for interest and looking here's the list :
-edelbrock victorx intake manifold setup- SOLD
Fuel system : all bought brand new by me less then 1000 miles - made 760+hp on pump e85 with this stuff
--Full blown in line fuel filter purple -10an each side with mounting bracket
--Full blown regulator black with liquid filled
gauge -10an and -6an return with push lok vac hose fitting in the regulator and hose and manifold fitting mounting bracket included
--Full blown fuel rail purple bseries -10an each side True -10 all the way through rail biggest rail on the market
*Have some brand new 10an black nylon braided hose and several black 10 an fittings that i bought and didn't need to use
-e85 ethanol sensor 6an for return line with Hondata plug and play harness - 100$
-bseries vtec valve cover painted in gloss red
Have 2 oem spark plug wire covers and 1 aftermarket as well 80$ for cover. And extra for spark plug wire covers
-Obd2b to obd1 rywire jump harness 60$
- Borg Warner s366sxe 66mm turbo super core billet wheel with .91 t4 divided exhaust housing with marmon flange. With black turbo blanket. Like new maybe 1000 miles have reciept I purchased new has 4an feed fitting and custom drain fitting that Borg requires for proper ID and proper drain . -750$ with turbo blanket
-Bseries 96-00 civic linkage. Skunk 2 dual bend shifter and skunk 2 weighted ****. Dimes perf. Solid bushings front and rear . - 200$.
(The **** and shifter alone are almost 200$ alone new plus the solid bushings are 80$ plus the cost of the linkage itself , I'd say this is a deal. )
-golden eagle lsvtec kit sandwhich plate. Used off engine has turbo feed line fitting on the sand which plate as well and has line for the head and the plate itself I do have the dowels but I do not have the fitting for the head . 75$
-Auto meter boost gauge silver face with blue light 50$ with push lok line and both push lok fittings
-Auto meter shift light with digital tach level 2 awesome thing to have. 140$
-CNC staging brake 140$. Just the Brake itself and one single stainless line with A T fitting on the end- nothing else you would need to get the lines that go from the T to each rear brake Can ad custom Made mounting bracket for 40$ extra it mounts next to center console
-used kseries coils oem Denso kseries type s- 75$
- black works racing coil pack mounting plate black in color use on bseries vtec head -75$
-brand new in box engine spark testing tool for coil packs or plugs 25$
-alum half size Radiator mishimoto brand SOLD
-Integra / eg bseries Tbracket 60$
-bseries trans torque mount bracket powder coated purple 100$
-brand new oem bseries ac compressor bracket bought from Honda and planned to use for aftermarket torque mount and didn't 100$
-oem bseries alternator obd2. Have 2 of these
-oem bseries starter have 2 of these
-oem bseries speed sensor have 3 of these
-96-00 civic 2 post Avid engine mounts with driver side avid bracket: Can Include trans mount bracket. Post mount bracket off engine. And t bracket. T bracket is a eg because car had eg subframe custom powder coat on brackets -400$ for all bracket and bolts and mounts. Or just mount kit 240$ with 3 mounts and driver bracket
-Stainless steel braided clutch line kit with brand new oem clutch master cylinder and res. and new slave cylinder oem Honda all bseries so complete setup -180$
-4an stainless oil feed line perfect length for bseries to run from sand which plate around timing belt to top mount turbo 30$
-Blox drags. Fronts look to be in ok shape have to check rears fronts only -sold.
rears -??( have to check condition )
-front suspension shock forks with bolts for civic Integra. Non si 40$
-Bseries Axles have some Honda ones and some auto store ones 100$ for each pair I have 6 total. So 3 sets
-bseries half shaft 50$
-99-00 front brake assembly hubs calipers rotors etc. has arp extended studs . could use bottomn ball joints replaced . Has new wheel bearings in both sides I just did recently . Aftermarket pads and rotors. Good Working shape - 150$
-drag racing lug nuts for slicks and skinnies. The 2 piece style with lug nut and wash. Recommended by weld and all drag racing companies for drag pack setups. Have 8 brand new in the pack and 8 used barely 75$ for all
-96-00 civic oem engine bay block off rubber caps. Like for the ac or the wire harness etc
-vms racing 10.2mm black spark plug wires for bseries vtec 40$
-oem Honda power mirrors fresh si blue. 100$ set
-4x100 cnc billet wheel spacers Hub centric. 9mm thick. Ran them with my slicks for some extra clearance Custom made for my car and any Honda 50$
-custom powder coated type r style front upper strut bar. Purple and black 75$
-99-00 headlight. I have one aftermarket gunmetal hosting driver side. And one oem clear passenger side 40$ each
-pwjdm purple battery tie down and spark plug wire bracket 40$
-99-00 si engine harness -150$ ( I have 3 of these )
-oem gsr dual bend shifter perfect shape. 60$
-3 custom made purple ground wires for engine Ask for pics 25$ all 3
-Skunk 2 pro series front camber kit 120$ (needs 1 ball joint )
Some more I'm forgetting but I'll remember
Old May 26, 2016 | 03:35 PM
Default Re: Race car sfwd ek civic turbo car part out 760+hp. Due to accident
Updated
Old May 29, 2016 | 08:46 AM
Larrylove59's Avatar
Originally Posted by 94eg5squadMD
Updated
U have stock sleeve and u claim this motor makes over 760hp?
Old May 29, 2016 | 11:05 AM
I don't claim it's proven. I have dyno graph I have video of the car on the dyno and the screen after a pull and plenty of people that vouch. Don't live in 2010 and beyond thinking that stock sleeve engines can't make power. I had a amazing fuel system. A great tuner if not one of the best in the usa and a great assembled engine with the right parts
I will be happy to prove to any serious buyer anything I said above
Thanks
Old May 29, 2016 | 01:25 PM
Thanks
Ok
Old Jun 1, 2016 | 06:10 PM
Updated
Old Jun 5, 2016 | 10:38 AM
Manifold sold rad sold
94eg5squadMD
Jul 2, 2016 07:56 PM
vinmotors
Appearance Build Threads
15
May 30, 2013 09:36 PM
EncoreRSX
Jul 20, 2010 02:57 AM
JoeDenso
Mar 11, 2009 09:04 PM
bomber
Northwest (Sales)
24
Apr 29, 2006 09:42 PM
