Is this weldable?( thin material)
Old May 25, 2016 | 01:45 PM
migrod1's Avatar
Default Is this weldable?( thin material)
Hi everyone, I removed the badge on my kamikaze header because it cracked and it was over runners 2 and 3 which made it a pain to check the oil. the badge is only 0.022" thick, is it possible to weld the crack? the material is 302 stainless steel.
Old May 26, 2016 | 01:18 AM
1HGEJ2's Avatar
Default Re: Is this weldable?( thin material)
yeah with 15-20ampere
Old May 26, 2016 | 03:44 AM
seelback's Avatar
yes
Old May 26, 2016 | 09:42 AM
migrod1's Avatar
I went to talk to a welder in my area and he told me because of how thin it was it would be difficult/impossible to weld? Would anyone on the forum be interested in doing it? I would pay of course
Old May 26, 2016 | 12:06 PM
Luserkid's Avatar
Whats the thickness and material? It could be done with TIG welding but its not gonna look as good but its very doable.
Old May 26, 2016 | 02:12 PM
migrod1's Avatar
Material is 302, thickness is .022
Old May 27, 2016 | 11:05 AM
Luserkid's Avatar
Have a piece of copper/aluminum/heat sink flat against the bottom and a piece of copper around the area to help with controlling the arc. Your arc out is what will probably kill the plate. Make sure that piece is clamped tight to the heat sink and it shouldnt be that hard. But again it probably wont look pretty.
slow_low_eddie
Nov 29, 2014 02:37 PM
B_Swapped93
Feb 15, 2014 05:18 AM
S2Integra
Welding / Fabrication
Jun 21, 2009 07:23 PM
MooreBoost
Jul 24, 2003 04:22 PM
