Honda CR-V & Element 2WD & 4WD Element & CR-V
Wondering how to do my tire/rim setup
Old May 24, 2016 | 01:47 AM
Liam Morgan's Avatar
Default Wondering how to do my tire/rim setup
2001 CR-V 5-speed
Hey everybody,
just trying not to make any mistakes that will require serious modification to mend. I have kumho LT235/75R tires that I'm looking to mate to some rims. I'm about to put in my OME lift springs (which by the way if you have advice as to how I should compress those bad boys, please let me know) so what kind of backspacing should I be looking for to avoid any rubbing? I'd like to shoot for the lowest offset possible (0 or maybe -6) to get that rally tires-stick-out-past-fenders look. So has anybody run 15x8 rims with 4.25-4.5 backspacing without need for serious modification? Thanks for any and all insight you all provide!
Cheers
Old May 24, 2016 | 05:29 AM
JoshTheJerk's Avatar
Default Re: Wondering how to do my tire/rim setup
You may still have to do some trimming and banging of metal in the wheel wells. You didnt mention if you have a 15 or 16 in rim. Also an 8mm spacer will usually help clear the calipers in front. Check out the lifted crv thread for tons of info
https://honda-tech.com/honda-element...d-%2A-3118056/
2kdrift
Suspension & Brakes
Nov 6, 2015 12:19 AM
NewtoCivics
Mar 25, 2012 05:39 PM
aln2590
Aug 23, 2007 11:05 PM
shaylude
Apr 4, 2007 07:37 AM
mickey513
Mar 30, 2002 06:03 AM
