Coil spring compressors
Old May 19, 2016 | 05:18 AM
masospaghetti's Avatar
Default Coil spring compressors
I've tried to disassemble the factory shocks from my 92 Accord and I was not able to find a spring compressor tool that would fit (all of them were too large, intended for MacPherson struts).
Has anyone used a compressor that worked?
Old May 19, 2016 | 06:29 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Coil spring compressors
I've used the two piece coil spring compressors on my '95(similar/same suspension as 90-93). McPherson strut spring compressors are made for larger springs/assemblies, not our coil-overs.
Old May 19, 2016 | 09:25 AM
I tried that style. That looks like a strut spring, I couldn't get them to fit my coilover spring?
Old May 19, 2016 | 12:10 PM
holmesnmanny's Avatar
Harbor Freight has one that works great.
Old May 19, 2016 | 01:04 PM
StokelesS_g2's Avatar
Why would you need a spring compressor to remove a coilover spring? Unless ya meant coil spring.
Ghetto way, step on spring/shocks and shoot off the nut with a impact gun. Make sure the area is clear first.
The shock will fling off a few feet or less.
Youtube goto to 5:50
Old May 19, 2016 | 01:23 PM
I thought the fronts were technically coilover shocks from the factory?
Either way, I would be installing lowering springs onto some new dampers so I would have to compress them to do it.
Old May 19, 2016 | 02:11 PM
Tachi's Avatar
I had a similar problem when putting lowering springs on my car. That tool mad Mike shows is the obi I used, and the own coils are close enough together that I actually had to disassemble the compressor and rock the bits in between the coils and reconnect with the threaded rod.
Old May 19, 2016 | 03:25 PM
MAD_MIKE's Avatar
MM Gruppe B
They are.
But most folks think 'coil overs' are only the name given to adjustable types.
F-150 guys call the factory coil over assembly a 'strut', it gets pretty silly when attempting to purchase parts.
If the ones you have don't fit the coils themselves, try using them on the coils and the top/bottom plates to compress/keep compressed the assembly so you can loosen/remove the shock nut safely.
jdmhatch1
Suspension & Brakes
17
Feb 27, 2009 06:54 AM
BB6-213
Honda Motorcycles
Nov 28, 2008 12:28 PM
Team Bukkake Sucks!!!
Jun 13, 2006 09:28 AM
01nhbgsr
Feb 23, 2004 03:47 PM
Eggman
Feb 16, 2004 08:13 AM
