Bypass main relay Civic 91 Si
Old May 16, 2016 | 07:56 PM
Gobiee's Avatar
Default Bypass main relay Civic 91 Si
Okay I have a civic 91 SI im able to start the car when i By pass the main relay but when I install a Brand new main relay I get the same problem NO power to ECU,fuel doesnt prime or my indicator wont turn on
Any ideas on what can cause this I can still use the car but when the wires arent secure well and they fall out the car dies
I have also checked my fuse and my connections behind both fuse boxes.
Old May 17, 2016 | 09:21 AM
Efnino's Avatar
Default Re: Bypass main relay Civic 91 Si
Hey I recently had that problem on my Ef. I bought the car with a bypass to the back of my dash fuse box. The yellow wire with black line with a gray dot was pinned into one of the power supply's in the fuse box
Old May 18, 2016 | 09:09 AM
fcm's Avatar
fcm
Old Fart
Have you checked for the 3 powers to the PGM-FI Main Relay, unplug the relay and test for 3 powers...
1- 12V constant, hot at all times.
2- 12V switched, hot in run and start.
3- 12V switched, only hot when cranking to start.
Also check the ground, [black lead] should have full continuity to chassis ground, [grounded at thermostat housing].
If all good, check for power at the injectors, [lead that is the same color at all 4 injectors] also check for power at IGP1 and 2 to the ECU. [will also be the same color as injector power lead. 94
Old May 18, 2016 | 10:02 PM
davidayala831's Avatar
I have the same problem plz let me know if u figure it out cuz im running out of ideas.
b18buck
Dec 28, 2009 04:36 PM
RMXmitch
Nov 1, 2007 03:46 PM
blackstar
Mar 13, 2006 06:05 PM
BigAnold
May 18, 2005 05:31 PM
mr. carpenter
Sep 21, 2002 07:47 AM
