92 Civic LX - What seals/gaskets are these in a head gasket kit?
Old May 16, 2016 | 02:21 PM
Mecca8383's Avatar
Default 92 Civic LX - What seals/gaskets are these in a head gasket kit?
I have a 92 Civic LX with 235,000 Miles.
I received a Head Gasket set from Rockauto, installed most of the gaskets/seals but still got some left over that I have NO CLUE where they go or what they are. I supplied a link to the gaskets.
The link is here:
More Information for VICTOR REINZ HS5731A
What are the 1st two gaskets on the far left(within the valve cover gasket in the pic)?
What is the gasket on the far right side with the 2 rings connected with a tip sticking out(small ring, large ring)?
Also...those 3 thin rings(within the valve cover gasket..dead middle), are those O-rings for the lower-half of the spark plug tubes? Shouldn't there be 4..not 3?
Let me know guys! I been searching Google for a week trying to figure out where these things belong. Thank You!
Old May 16, 2016 | 09:20 PM
StokelesS_g2's Avatar
Default re: 92 Civic LX - What seals/gaskets are these in a head gasket kit?
Left gaskets are thermostat gaskets, looks like 2 options.
Middle 3 rings usually come in 4 in my searches.
Only gasket I can find that looks like the little snowman is timing cover gasket.
GL
Old May 16, 2016 | 09:22 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Far left is for thermostat... well at least one is. Others I am drawing a blank too.
Old May 17, 2016 | 05:54 AM
09chaplak's Avatar
Loves Tossing Salad
One for the crankshaft seal, one for the oil pump and other for the water pump? I'm like 75% on the first two.....
Old May 17, 2016 | 06:02 AM
24TEN's Avatar
PHANTOM MENACE
I'd back this statement on the basis that this looks like an all inclusive kit for all D-Series heads.
Those all go underneath the rocker arm assembly with the double O-ring being the fourth ring. The extra tiny ring attached to it seals the passage for the oil jet.
Old May 17, 2016 | 06:06 AM
09chaplak's Avatar
Loves Tossing Salad
Swing and a miss.
Old May 17, 2016 | 08:26 AM
tony_2018's Avatar
Fish Twig
Default Re: What seals/gaskets are these?
I was thinking the same thing, I see like 3 different throttlebody gaskets...its like a universal d-series kit.
Old May 17, 2016 | 10:41 AM
Mecca8383's Avatar
Ahh!! I see now! I was about to cut that little ring off the double ring and make it like the other 3 rings, since they're all the same size...LOL!
Thank you guys for all your help...now the only seals I have left are the valve stem seals left to install....which I believe to be a bigger job than most....I'll save them when I need them...
Old May 17, 2016 | 12:37 PM
24TEN's Avatar
PHANTOM MENACE
2 different intake manifold gaskets too, one looks like my original 8 valve port size. There's even what looks like a DPFI gasket in there as well.
Old May 17, 2016 | 11:55 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 92 Civic LX - What seals/gaskets are these in a head gasket kit?
bunch of extra crap you wont need.
Old May 18, 2016 | 05:20 AM
tony_2018's Avatar
Fish Twig
F'in waste....
cyclonedr
Sep 2, 2019 01:09 PM
HiGhGuY
Jul 30, 2014 10:13 AM
dohcteg
Dec 23, 2006 12:03 PM
