CRX Si ZC D 16 1.6L SOHC 16v cam spec
Old May 16, 2016 | 08:27 AM
hcrx91hp's Avatar
Default CRX Si ZC D 16 1.6L SOHC 16v cam spec
I need specs on CRX Si ZC D 16 1.6L SOHC 16v cam to compare to d15b2 cam.
Old May 17, 2016 | 05:53 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: CRX Si ZC D 16 1.6L SOHC 16v cam spec
Google. Check FAQ. This is a topic that has been covered in great detail many many MANY years ago. Good luck!
Old May 17, 2016 | 08:14 AM
hcrx91hp's Avatar
Thanks for the input but i'v already tried both with no success.
Old May 17, 2016 | 02:05 PM
24TEN's Avatar
PHANTOM MENACE
From the FAQ:
6. Engine
k. The D-series engine
3. SOHC cam specs
Try harder next time Also try searching through "Mista Bone's" posts. I believe he's personally documented the most regarding D-series parts and specs. I hope his info will help you accomplish whatever you're trying to do with your engine.
89D15CRXDX
Oct 22, 2006 02:23 PM
QuickStyle
10
Aug 27, 2006 03:00 PM
jdminthemakin
Aug 4, 2006 11:10 AM
rice is nice
May 31, 2005 09:12 AM
davens
Feb 6, 2004 07:21 AM
