I can't slam my ef!
Old May 16, 2016 | 06:20 AM
Gage Macbay's Avatar
Default I can't slam my ef!
So I got a new set of coils for my ef and the rear fit
perfect. But I can't seem to slam the front. I lowered the coilover as much as I could and still need to go down about half a inch for it to be flush. I'm tucking in the rear with like a inch of adjustment left and want to tuck the front but it won't let me go lower. Any suggestions or ideas on what might be wrong?
Old May 16, 2016 | 06:35 AM
kingkau's Avatar
Default Re: I can't slam my ef!
What kind of coil overs did you buy?
Old May 16, 2016 | 07:15 AM
bbarbulo's Avatar
I'm sure you're aware of the issues that 'slamming' causes. Assuming you still want to go ahead with that:
1. Normal for a civic rear to be adjusted higher than the front
2. Set the front at the lowest, then adjust the rear up to make it level
3. If this isn't low enough, start cutting the front springs or relocate the front spring perch on the shocks assuming you are using sleeves and not actual coilovers
Old May 16, 2016 | 11:34 AM
.Manny.'s Avatar
Touching My Member
Just hack ****, you're already ruining the car.
Old May 17, 2016 | 11:47 AM
BLU CIVIC's Avatar
Track Advocate
I got happy when I read the title
rudyndrew
Honda Fit
Jan 14, 2011 10:12 AM
chase7687
Suspension & Brakes
Nov 3, 2009 06:48 AM
93civicjaydm
Nov 29, 2005 02:23 PM
ATS_Antone
Jan 28, 2004 08:12 PM
Blown90hatcH
Oct 24, 2001 01:45 PM
