Car starts then stalls
I have a 1990 honda accord lx. It started to stall when I start the car and after a few tries it would run. The problem got worse and started happening more frequently and got to the point where it would start and stall no matter how many times I tried starting the car. I replaced the fuel filter, and the car ran fine after that, then I went to go full up with gas and then started the car and the problem came back and wouldn't go away. I took off the inlet hose to the fuel filter and tested to see if the fuel pump was going bad or if the inlet hose was clogged. Fuel came out fine when I turned the car on so that wasn't the problem as far as I know. I checked the fuel injectors the other day and those were fine and today I checked the idle air control valve and cleaned it and put everything back together but the car still starts and Dies immediately. Can I get some help on this? Much appreciated.
CimorelliCRX
Apr 7, 2022 12:16 PM
