Motor mount replacement
Old May 6, 2016 | 04:46 AM
My 93 accord's Avatar
Default Motor mount replacement
To change the passenger side motor mount on my 93 accord do I have to put the car on jack stands and could I could the transmission up a little to change it?
Old May 6, 2016 | 06:59 AM
masospaghetti's Avatar
Default Re: Motor mount replacement
Manual or automatic transmission?
You need to lower the transmission to get the mount out. It's trapped between the transmission and body. You might be able to do it without jacking the car up but i've never tried. Just support the engine with a floor jack and 2x4 under the oil pan.
Old May 6, 2016 | 07:35 AM
Automatic
Old May 7, 2016 | 03:35 AM
holmesnmanny's Avatar
You might need to wedge a pry bar against the driver side mount and frame to move the engine towards the transmission so you can tighten the through bolt down onto the new tranny mount. The reason is to be careful not to strip the threads on the bolt.
Old May 7, 2016 | 09:39 AM
I change the drivers side now for the passenger side the tranny mount what is the best point to jack up tranny?
Old May 8, 2016 | 02:14 AM
Anywhere under the tranny will raise the tranny. Just be sure to have a wooden block of some sort in between. You do not want to crack the tranny. You will just slightly raise the tranny, remove the through bolt, then let it down to remove the mount.
zspy_007
Dec 27, 2007 12:40 PM
integra3586
Feb 15, 2006 09:48 AM
mr_ek9
Jan 30, 2006 02:33 PM
mykal
15
Sep 25, 2004 08:11 PM
preluda92
Oct 27, 2003 06:13 AM
