J30a1 performance parts
J37A4
2009-2014 Acura TL SH-AWD
Displacement: 3,664 cc (223.6 cu in)
Bore and stroke: 90.0 mm (3.5 in) x 96.0 mm (3.8 in)
Compression: 11.2:1
Power; torque: 305 hp (227 kW) @ 6300 rpm; 273 lb·ft (370 N·m) @ 5000 rpm
Valvetrain: 24v SOHC VTEC (intake and exhaust)
Fuel control: Multi-point fuel injection; PGM-FI
Compression: 11.2:1
Been there man. The cylinder head intake ports are way too small to build any HP. Full bolt-ons and a tune only yields around 190-210 HP to the wheels.
We learned to swap out that J30A1 with a J32A2 or J35A3/A4 along with the weak *** 4 speed auto. It is not all plug and play, some custom stuff needs to be done. But you yield around 260 to 300HP to the wheels, depending on your tuning solution.
1racer
Jan 31, 2005 05:39 PM
