1995 Honda accord d4 light not working at all. And has no power in d4
Was working fine but I took out the ECU fuse to reset cel after replacing vss. I lost the fuse but I tried replacing and it started doing this. I put in d4 to drive and it just revs but doesn't actually move. It automatic , I can drive by manually shifting but it starts smoking from transmission area. Need help ASAP . do i just get all new fuses ?
I assume all fuses are in place .... if you have smoke from the transmission .. this is serious .. could be no oil inside transmission ... and finally your transmission is toast. Check for leaks beneath your car ...... look for engine and transmission oil leakage. Have your transmission checked ASAP.
tuongtu3
Jun 22, 2017 09:06 PM
psyce_raven
Nov 2, 2009 04:49 AM
mcbeats
Sep 21, 2009 10:50 PM
mrhondafrustration
Sep 15, 2008 11:18 PM
