Del sol - Are aftermarket roof holder lift support struts available?
Old Apr 29, 2016 | 03:41 PM
jdspeed99z's Avatar
Default Del sol - Are aftermarket roof holder lift support struts available?
Does anyone know if there's an aftermarket part or are these only OEM, which are discontinued.
Del sol roof holder lift support struts
Thanks
Old Apr 29, 2016 | 03:59 PM
burnoutboy's Avatar
The Credible Hulk
Default re: Del sol - Are aftermarket roof holder lift support struts available?
del sol support struts | eBay
del sol support struts | RockAuto
Didn't even google, did you? DID YOU?!?!
Old Apr 29, 2016 | 04:51 PM
jdspeed99z's Avatar
Those are not for the ROOF HOLDER.
Yes I googled, I majestic honda'd, I rock auto'd, I spent over an hour searching this site.
There's nothing about ROOF HOLDER lift supports here, and there's one pair of USED ones on ebay. I do not want 20 year old used lift supports.
Old Apr 30, 2016 | 06:23 AM
Former User's Avatar
Default Re: Del sol - Are aftermarket roof holder lift support struts available?
New ones are available on eBay.
Del sol roof holder lift support struts | eBay
Old Apr 30, 2016 | 11:57 AM
slomofo's Avatar
GDD Member
Majestic Honda has em in stock.
Give em a call.
Old Apr 30, 2016 | 02:19 PM
jdspeed99z's Avatar
74740-SR2-305 012 002 STAY SET, ROOF HOLDER OPEN Discontinued 58.83 41.18 Qty:
Buy
No, Majestic Honda does not have them in stock, they're discontinued. And 21 year old ebay lift struts are not what I am looking for they won't hold the roof up. Thanks.
Last edited by jdspeed99z; Apr 30, 2016 at 02:20 PM. Reason: Highlighted word didn't show up
Old Apr 30, 2016 | 02:33 PM
JarvisW's Avatar
Sol to Sol
That sucks man.
They aren't much smaller than the trunk ones, maybe take one of each off and compare the sizes?
Or get the dimensions and try to match it at the parts store?
I am prob gonna need 4 of these before its all over, so good luck in your quest!
Old Apr 30, 2016 | 02:43 PM
jdspeed99z's Avatar
Looks like they were custom made by Showa for Honda, they have a number on them 3D20 that's it. and it doesn't cross reference to anything. They measure out to about 14.5" x 9.5" and I don't know the weight rating, but There's a universal strong arm that has ball ends on both ends that with some cutting and welding will work.
The strong arm part numbers are 4517, 4683, 4518, Those are 60lb, 75lb and 100lb lifts.
Old Apr 30, 2016 | 06:46 PM
eghatch9295's Avatar
Stancetard Hate Monger
used are about as good as itll get. i have a good pair from a 128k mile del sol i parted, good luck with finding new.
Old Apr 30, 2016 | 10:37 PM
JarvisW's Avatar
Sol to Sol
Yeah I hate that propriatary crap. On dads Sol I had to use a dremel with a cutting wheel to cut them off the posts, then the replacement ones (Which you CAN get at auto stores or Rock) just snapped back in, or had a lil clip or something. (it was like 5 yrs ago lol)
Anyway, good luck, and the LB rating should only be like 10-15lbs ea? that roof and rack can't weigh a lot, plus using the pivot as a lever takes some off too.
What I'd like to do is get some for the hood! I'd just need to weld in some tabs to hold them, just not sure when I'll ever get around to it.
Old May 30, 2016 | 07:42 AM
jdspeed99z's Avatar
I ended up cutting the studs off and using a universal strut, and a bolt in ball post. Worked fine. The oem looked like a ball & socket wouldn't have the range, but it worked just fine. Thanks everyone for the support.
Old May 30, 2016 | 11:31 PM
JarvisW's Avatar
Sol to Sol
Good to know, do you have the specs on the universal struts or did they fit your above measurements?
Old Jun 4, 2016 | 05:12 AM
jdspeed99z's Avatar
I do, They were strong arm universal lift supports.
4517 ~60lbs of lift
4683 ~75lbs
4518 ~100lbs
I went with the 4683 from amazon, and they're actually a little too strong, but should last forever. And also used PN SA3000 ball stud mounts. works like a charm.
Old Jun 4, 2016 | 01:30 PM
JarvisW's Avatar
Sol to Sol
Cool thanks!
Old Jun 4, 2016 | 06:21 PM
oneheadlight's Avatar
I found the sachs replacements for the del sol's trunk and they come with new ball attachments. I found them for cheap at rockauto..
Old Jun 4, 2016 | 08:20 PM
JarvisW's Avatar
Sol to Sol
yeah, that's not the ROOF supports tho.. That's the problem OP had
Old May 4, 2025 | 07:23 PM
Hons del solo's Avatar
Hey Boys,
Strutwise can rebuild them for $48 per strut. Toasting in epic bread!
craklingice
Apr 17, 2015 05:23 PM
grape1161
Nov 12, 2010 08:58 AM
uncivilizedracer
Jan 3, 2006 02:34 PM
g3teg97
Dec 9, 2005 04:08 AM
DELshow
Nov 30, 2003 10:28 AM
