Accord 01 LX p1381 reset while driving
I'm using jumper wires connected to number 13 fuse slot . P1381 cylinder position sensor error idle bumps down intermittently every couple seconds or so and then throws code put it in limp mode also. Can I reset the p1381 code while driving? I can get the car to drive fine put in Reverse it pulls down RPMs to 700 starts bumping down again throws p1381 code and limp mode so I reset it and keep going so at this point what I want to know is if I can reset code while driving using the jumper wires going from the fuse slot to the Dash thanks , Tailwind
Because I'm not sure what the problem is it could be Electric wires or connectors could be that cylinder position sensor I could replace the whole distributor with a used one and find out that's it's not the problem or defective not the problem way out in the Sticks weather is a problem to say the least and I'm in a pinch thank you from my research new Distributors aren't made anymore so that's a whole new can of worms..... what would be really great it says I could just disable the sensor but from what I understand it's all goes an electronic Loop kinda like old Christmas light bulbs if One sensor doesn't work then it's messed up am I right thanks thank you thank you I need some Tailwind I wish I could just disable the cylinder position sensor and everything would be just fine but apparently it might not be that easy
