1999 intwgra LS- asking noise when turning left and dropping into small indents on ro
so I have a 1999 acura integra LS on yonaka coilovers it probably dropped like 1.5 to 2 in, I changed all my front suspension, LCA, upper ball joint, inner and outer tie rods ends, new axle, lower ball joint, everything I hit a bump or slight indent on the road I here a clunking noise and also when I turn left, I've checked everything to make sure nothing was loose, everything was tight even went as far as tightening my sub frame bolts, and checking motor and tranny mounts, I had my car at the shop because I hit something on the road on my left side , they replaced LCA upper ball joint, new axles new inner and outer tie rods end and rebuilt my coilovers on both sides, just to make it clear my car was making the noise before the accident happened, I took it back to the shop cuz of the noise and they have not been able to tell me what it is!! help a teggy friend out
hawksftball2007
May 5, 2015 08:24 PM
picthis1
Feb 1, 2012 08:32 PM
SiRkid
12
Jun 9, 2005 12:05 PM
