Toda spec b cams for turbo?
Old Apr 23, 2016 | 11:06 PM
lindseyhunt1090's Avatar
Default Toda spec b cams for turbo?
Hello everyone. Just wondering if anyone has any experience with running toda spec b cams in a higher hp turbo setup (700-800hp) ive found a little info on them from back in early 2000s. no solid facts just speculation. ive been running them for a few years. i made 640whp on a gt35r (27 psi) i upgraded my turbo from a gt3582 to a forced performance htz 3586. im shooting for 750 to 800 in the next few weeks and just didnt want anything to hold me back. The cams seemed to perform well but not sure how they will act at the higher boost levels. anyone? here are the specs.
TODA B:
adv duration-> int:295/ext:285
Pri/Sec lobe lift: 11.0mm(int&ext)
Vtec lobe lift: 12.0mm(int&ext)
Valve lash:0.2mm (cold)
intake:
pri/sec lobe:
int open BTDC:0
int close ABDC:30
cam top center:105
duration@1mm:210
vtec lobe:
int open BTDC:25
int close ABDC:50
cam top center:102.5
duration@1mm:255
exhaust:
pri/sec lobe:
ext open BBDC:30
ext close ATDC:0
cam top center:105
duration@1mm:210
vtec lobe:
ext open BBDC:45
ext close ATDC:20
duration@1mm:245
sorry if this makes no sense its really late and im scatter brained.
EGkid
Jan 4, 2005 07:04 PM
hqrcrx
Dec 10, 2004 06:48 PM
MaD3 In JaPaN
Feb 18, 2002 03:48 PM
SpeedMonkeyRacing
Oct 21, 2001 02:04 PM
