90 integra db1 vibration/shakin help
Old Apr 23, 2016 | 08:48 PM
DavidDb1's Avatar
Default 90 integra db1 vibration/shakin help
Hi I have 1990 Acura integra sedan. I have shaking/vibration from driver side when accelerating or when over 60 mph it gets worst, even while coasting it's still there, I've replaced axels, lower control arm bushings, ktuned traction bar, upper control arm bushings, inner and outter tie rods, rack and pinion bushings, just got alignment done, tires are balanced and rotated them to see if that made a difference and it's still happening. Have spindles with new lower ball joints and wheel bearings I'm puttin in Monday in hopes that will solve it(will a bad ball joint cause that much vibration/shaking?) if after the spindles are put in and no luck any ideas of what else it could be? Thanks
Old Apr 25, 2016 | 05:19 PM
alec1241's Avatar
Default Re: 90 integra db1 vibration/shakin help
Check the motor mounts, especially the rear. My '92 GSR was doing the same thing, replaced both axles, still shook. Checked the rear mount: it was ripped clean through. Hope that helps. btw: the rear is a nightmare to change...
Slowbro
Jan 5, 2015 10:51 AM
Rob.
11
Jul 8, 2012 07:13 PM
Rob.
Suspension & Brakes
Jul 8, 2012 10:29 AM
92integraVTECgsr
Suspension & Brakes
Oct 3, 2007 10:01 PM
Chase Taylor
Apr 7, 2004 04:06 PM
