Pop when making fast left turns
Old Apr 23, 2016 | 05:56 PM
jackdog1's Avatar
Default Pop when making fast left turns
I just bought a '01 Accord EX v6 which runs great, however I've noticed that when I make tight left turns I hear a single pop from the wheels (pretty sure it's the left wheel). I know it's not the CVs, so I'm guessing tie end or ball joint?
Old Apr 24, 2016 | 01:54 AM
holmesnmanny's Avatar
Default Re: Pop when making fast left turns
You could have bad control arm bushings. If they are making that kind of sound then they should be fairly busted and it should be visual.
It's entirely possible it is a bad cv joint though.
Old Apr 24, 2016 | 10:42 AM
jackdog1's Avatar
Problem found: busted right sway bar link
Old May 22, 2016 | 07:48 PM
HondaxAcura's Avatar
I had the same problem! + a broken joint
William1991b
Oct 18, 2017 09:57 PM
EJ8_MEX
Oct 12, 2017 08:30 PM
boost4life1
May 2, 2012 11:59 AM
sunil6784
Dec 21, 2005 10:13 AM
el_Presidente
Dec 5, 2001 01:16 PM
