EK JDM H22A Swap Wiring Questions
Old Apr 23, 2016 | 11:08 AM
Accordian47's Avatar
10 Year Member
Default EK JDM H22A Swap Wiring Questions
Plan on putting a JDM 92-95 H22A Engine in a 2000 Civic EX Coupe.
The motor/harness/ecu/prelude the motor came from is OBD1, unsure of the exact year but being from 92-95...
The EK is OBD2b and I am buying it without an engine/transmission or harness.
This is my plan: Buy an OBD1 Civic EX Harness, modify it to fit the H22 and run the OBD1 JDM H22 ecu that comes with the swap.
This would mean I could have a OBD2b chassis running an OBD1 ecu and engine. Would this be the way to go? As far as differences between the harnesses, are the prelude and civic harnesses both 1 piece? Engine to ecu? My other question is on the ecu end of the harness, would the OBD1 Civic EX harness plug into my JDM OBD1 H22 ecu? Would I need an OBD1 to OBD2 conversion harness for any reason? Sorry im a little confused and searching has given me a headache. Any help is appreciated.
OR: Is it an option to just run the JDM Prelude H22A engine harness and ecu?
Thanks,
-Ian
Old Apr 23, 2016 | 12:58 PM
10 Year Member
Default Re: EK JDM H22A Swap Wiring Questions
I have found that the 96-00 Civic engine harnesses are 1 piece, from sensors to ecu, so I know that but that is for OBD2, are the 92-95 OBD1 civic engine harnesses 1 piece as well? or are they 2 piece, stop at the shock tower type?
Old Apr 23, 2016 | 01:03 PM
10 Year Member
From looking at pictures of harnesses on ebay, it looks like 92-95 OBD1 civic harnesses are the two piece design.
SO, would the thing to do be run a OBD2 96-00 civic ex/si harness, modify it to fit the H22A and run an OBD2b to OBD1 conversion harness for the JDM OBD1 (P13) H22 ecu?
Old Apr 25, 2016 | 04:27 PM
10 Year Member
Oh my god, I searched...just delete this
Mastgohn
Jun 6, 2016 10:18 AM
Accordian47
Apr 25, 2016 04:55 PM
OMGrimmy
Apr 10, 2011 03:01 PM
BritishBulldog
Jun 16, 2005 03:18 PM
shadowludeJDM
Mar 29, 2004 07:17 PM
