95 accord cluster interchangability
Since my odo and gas gauge are broken, I'm going to replace the cluster. The yard wants 50 for one, no warranty and no guarantee. I'm not too comfortable with that considering this appears to be a semi common problem.
I was looking on Craigslist and found one for a 95 EX, I assume that will work, but the guy wants 70 for it.
Are there any other clusters that will fit, or am I limited to the 94-97?
Most pick and pulls will let you return a part within 30 days if it doesn't work and still has the markings they put on it. You need to find another yard.
I talked the guy down to 40 on the cluster, I'm going to pick it up.
One last question, the cluster came from an automatic ex. I'm assuming that the only difference is the PRND lights, will the cluster work?
I can hide the PRND lights, as long as the rest of the cluster will work.
Where I live that's not the case. If the electrical part doesn't work it can be returned. I deal with LKQ which is a national chain. If there are others in driving distance I would ask them their policies.
