... ultimate street car setup... if you could build it...
Smarter than you
Turbo Z06. built 427 bottem w/ LS6 heads. something larger then a T88. similar to lingenfelters that raced the jet but single turbo instead of twin.
Any car - WRX with VF22 turbo, and all the goodies that make it run well.
Honda based - ITR w/B20 block, ITR head and a well tuned jrsc. Add a 50 shot for those times when pesky turbo'd hondas are giving you trouble.
http://www.thedodgegarage.com/consulier.html
go with a 2.2 - 2.4 Liter turbo DOHC motor of some sort.
Smarter than you
Darton sleeved b18c1...85mm bore
Ported type r head w/ oversize valves and valve springs
Crower Turbo cams
Eagle Rods..
Endyn 9.0CR pistons
Skunk2 IM
4 DSM 440CC injectors
4 secondary 550CC injectors
Custom Fuel Lines
Aeromotive 1000Hp fuel pump
Arp head studs
Inline Pro Head Gasket
LS tranny w/quaiffe and type r 3rd and 4th gears
Custom greddy 4-row intercooler
Blitz sequential bov
MSD Ignition
3 bar map sensor
Methanol Injection Kit
t4 60-1
Apexi AVC-R Boost controller
JimFab traction Bars
Koni yellows w/ Eibachs
DriveShaft Shop Stage 5 axles
30lbs of boost everyday
Crower Turbo cams
Eagle Rods..
Endyn 9.0CR pistons
Skunk2 IM
Custom Fuel Lines
Arp head studs
MSD Ignition
3 bar map sensor
t4 60-1
Audi S4 with 500ftlbs... leather, ac, style..
Rx-7 tri rotor with Turbonetics Y2K and Methanol injection. No luxury spared inside. with a freezer/microwave combo in the passenger dash, cooler of drinks (non-alcoholic) in the passenger seat
EDIT: Natalie Portman Handing me drinks from the passenger seat
[Modified by Pelican, 5:40 PM 11/7/2002]
a high hp s4 would be pretty sick.
that cobra is awesome too
dont get me started on how awesome porsches are
[Modified by SiRkid, 12:33 AM 11/8/2002]
Crower Turbo cams
Eagle Rods..
Endyn 9.0CR pistons
Skunk2 IM
Custom Fuel Lines
Arp head studs
MSD Ignition
3 bar map sensor
t4 60-1
Crower Turbo cams
Eagle Rods..
Endyn 9.0CR pistons
Skunk2 IM
Custom Fuel Lines
Arp head studs
MSD Ignition
3 bar map sensor
t4 60-1
Drive on 30" slicks every day????......
mine would be a 1990 gold civic hatch with everything stock on the outside and the interor. stock ride height and all. as far as under the hood i'd get a dart b20 block with 8.5-1 comp pistons crower rods lightened and balanced crank ..port flow head work with enlarged valves and a 5 angle job. ferrea roller cams and springs, jg intake manifold plumbed with a 100 shot direct port.. oh and 1 last thing rev hard tubular stainless mainfold with a turbonetics T-4 ball bearing turbo 3 inch down pipe with a painted black apexi delta fin intercooler with 3 inch intercooler piping all the way through and to let off all of that pressure a tial 50mm b.o.v and a 46mm wastegate. i think this would be the formula to smoke any vette or viper with a car you could build for less than it would cost to keep gas in one of those things for a year.
Vapor Trail's car if i were building a Honda
see his sig for details
for what i really want
99 BMW M3 Sedan Turbo
Crower Turbo cams
Eagle Rods..
Endyn 9.0CR pistons
Skunk2 IM
Custom Fuel Lines
Arp head studs
MSD Ignition
3 bar map sensor
t4 60-1
Crower Turbo cams
Eagle Rods..
Endyn 9.0CR pistons
Skunk2 IM
Custom Fuel Lines
Arp head studs
MSD Ignition
3 bar map sensor
t4 60-1
