Honda CR-V & Element 2WD & 4WD Element & CR-V
Solenoid "c" stuck open/has a hard time with reverse and O/D
Old Apr 21, 2016 | 12:39 PM
Evo7886's Avatar
Default Solenoid "c" stuck open/has a hard time with reverse and O/D
Hello, I have an 04 element AWD with codes p1732 & p0797. 1732 refers to shift solenoids b/c stuck open/on. 0797 is strictly solenoid c stuck open. Steps taken to narrow down the cause
-changed and drained the fluid 3 times for a complete fluid change
- cleaned the solenoids (4) behind the solenoid cover (some improvement I think)
- swapped spots with corresponding solenoids to check for a change in gears mishifting (no change)
Going into O/D it revs high and does not engage, I can drive with it off. Just recently it starts to try and engage but seems like it's dragging or not fully engaging and if I accelerate it will start to rev again. Going into reverse it takes a few seconds and if I give some gas it will speed up the process, whereas before I cleaned the solenoids it never fully engaged. I think I'm on the right track but I really don't know what to do next, any help would be appreciated, thank you for reading.
Old Jun 6, 2017 | 06:18 AM
Manuel Olivo's Avatar
Default Re: Solenoid "c" stuck open/has a hard time with reverse and O/D
hey I know this was a long time ago but any luck figuring out the problem I'm dealing with it now.
carcrazy746713
Acura TL, RL & ZDX
Jun 8, 2017 09:44 AM
MacR6
Jan 13, 2014 04:38 PM
slideintegra08
Honda Civic (2001 - 2005)
Jan 5, 2011 10:19 PM
onyx00
Oct 1, 2001 05:02 PM
