GSR Vacuum Leak at Intake Air Bypass (IAB) Spring / Shaft
Old Apr 19, 2016 | 04:01 AM
Gekko's Avatar
Default GSR Vacuum Leak at Intake Air Bypass (IAB) Spring / Shaft
I suspected a vacuum leak in my 1999 GSR and did a smoke test. The test revealed a very noticeable leak coming from the area behind the spring attached to the IAB shaft.
Has anyone ever taken one of these apart? I'm wondering if I can remove an O-ring or something without taking off the whole intake manifold. Or, even if I take off the manifold, are there serviceable seals for the IAB shaft?
Old Apr 23, 2016 | 11:33 AM
wasanissanFL's Avatar
Default Re: GSR Vacuum Leak at Intake Air Bypass (IAB) Spring / Shaft
I don't think this is a serviceable part. I don't see fasteners to open it up, and there are no part numbers for any type of seal inside the unit. I would try a used replacement, or a new unit from Acura.
Here's the part number for a new valve. It's around $60-70.
17129-P72-000
Old Apr 26, 2016 | 04:32 AM
Gekko's Avatar
Thanks for the reply. All the online Acura places I've checked show that the valve assembly is discontinued. I think 17129-P72-000 is the diaphragm and 17120 is the valve assembly, including diaphragm. Do you know a place that still sells the whole assembly?
Old Apr 26, 2016 | 07:08 AM
WilsonsB18C1's Avatar
I had the very same issue a few days ago. unfortunately i disabled the secondaries(Due to some bad information). removed the assembly and left the actual shaft inside the intake and used RTV to seal the leak at the shaft. Currently searching for a oem manifold with the butterfly intact.
Old Apr 26, 2016 | 09:01 AM
Gekko's Avatar
When you took it apart to remove the butterflies, did you take the whole manifold off the head? I'm wondering if I have to take off the whole manifold to service this thing, or if I can disassemble at the IAB and leave the fuel rail, etc still intact.
Old Apr 29, 2016 | 09:26 PM
You can disassemble it without removing the intake from the head but I would suggest just removing the entire manifold because it's a pain in the *** to put it back together while fighting the hoses and wiring.
Old Apr 14, 2023 | 06:13 PM
01DB8_Gs-R's Avatar
Did you find a solution?
validheadshot
Dec 9, 2012 09:58 PM
d15bflat
Jul 12, 2009 11:25 AM
kauai96
May 30, 2009 12:44 PM
DC2SIR-G
Oct 17, 2005 01:08 PM
koco
Feb 16, 2003 02:37 PM
