Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 Accord turns over won't start
Old Apr 18, 2016 | 06:36 PM
carolinacole's Avatar
Default 2003 Accord turns over won't start
A few days ago my blower motor quit working after trying use the accessory cigarette plug.
Figured it was a fuse and was checking them out. I only checked 4 fuses.
Now car will not start and I figure t's a bad fuse or relay having to do with fuel pump.
Just checking to see if anyone has a starting point or has had similar problems before.
Old Apr 18, 2016 | 06:59 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2003 Accord turns over won't start
First check/re-check under-dash Fuse No. 32 (7.5A) and No. 9 (15A).
Then check the under-hood Fuse No. 23 (50A/50A), which is a large multi-fuse.
Old Apr 19, 2016 | 06:21 AM
These fuses are intact.
What should I look at next?
Old Apr 19, 2016 | 06:42 AM
Disconnected to battery cables and touched them to reset ECU.
Tried to start after and after about the 5th or 6th time started to sound sluggish like weak battery.
Old Apr 20, 2016 | 03:11 AM
Any ideas?
Old Apr 22, 2016 | 04:29 PM
poorman212's Avatar
Do you have a volt meter to check the static voltage of the battery? Should be in the 12.5v range. If not pull the battery and have it tested, many parts stores will test and charge if needed for free.
While the battery is out, be sure to clean the cable ends, and when you install. Be sure they are tight.
dc2teg2006
Mar 28, 2009 05:31 PM
seamus657
Mar 6, 2009 08:47 PM
Tip14
Dec 27, 2007 01:13 PM
b20vtecEK
Apr 5, 2005 11:45 PM
Train
Jun 2, 2004 08:15 PM
