Crx undercooling
Old Apr 18, 2016 | 08:24 AM
Granulatedsugar's Avatar
Default Crx undercooling
My crx heater doesn't work so I flushed the heater core. The heater still didn't work after that so I tried flushing it again and still the heater doesn't work. I noticed the temperature needle never got to half or close. It only ever gets about to 1/4. So I thought for sure the thermostat was stuck open. I took it out and it was like new. Works fine. Now I am stuck. I drive the crx everywhere still but it never has heat and it never warms up. Anyone have any clue to what it is? Or could be?
Old Apr 18, 2016 | 11:55 AM
Tyson's Avatar
Default Re: Crx undercooling
I hear you saying you think your heater core isn't even getting hot, but have you checked the cable linkage under the core? It's a common issue for non working heaters.
https://honda-tech.com/honda-crx-ef-.../#post43614304
Old Apr 18, 2016 | 12:10 PM
The heater doesn't work at all.
Old Apr 18, 2016 | 01:19 PM
Tyson's Avatar
As in, no heat, right?
I don't think you read the link....
Old Apr 19, 2016 | 05:12 AM
Yes, no heat is correct. I checked for the linkage underneath the dash (air mix flap or whatever it is) and it looks connected. Could I be looking at the wrong one or something?
Old Apr 19, 2016 | 02:33 PM
fcm's Avatar
fcm
Old Fart
Yes, place check water valve linkage/cable at firewall behind engine on pass side... http://www.hondaautomotiveparts.com/...R+VALVE+-+DUCT #23, make sure valve is working. 94
tanndaman
Feb 13, 2008 03:49 PM
crxtreme27
14
Apr 21, 2003 03:01 PM
JDM CRX
Feb 27, 2003 11:09 AM
tremor86
Dec 5, 2002 06:11 PM
type Gendy
Oct 29, 2002 04:16 PM
