Distributor swap?
I need a diagram to rewire a two plug distributor to a single 4 wire plug to go into my harness. Did motor swap over and new distributor has 2 plugs instead of the one plug from my old one. My friend tried to help and rebuild it for some reason and fucked it all up. Any help would be great
Its very simple. 2 wires. One is the blue for the cluster and not mandatory to get things running. Just connect the blue however you want, use the 2 pin connector or wire it directly.
Look here
https://honda-tech.com/hybrid-engine...972711/page17/
Blk/yellow is the wire you should be concerned with. This should be wired into #5 on the OBD2b plug.
Look here
customs-25
Aug 27, 2015 07:24 PM
LivinDreamsEK9
Sep 3, 2007 10:30 AM
