93 Del Sol Si - mini-me and clutch questions...
Okay, so my nephew has a '93 Del Sol Si SOHC that he recently rebuilt the engine for. He calls it his Frankenstein because he has put his Y8 head on his Y7 engine and went from d15B to d16y7. It is not built for high performance, just for a daily driver.
Is there anything special he should know about this set up?
Also, his helper "forgot" to install the lower crank position sensor. Will it work without?
Next, clutch: Is this the correct clutch?
He's also going to need the clutch master and slave. I haven't looked them up on Amazon yet. What do you guys recommend?
go get the slave from your local parts store. around $25 with lifetime warranty. install the ckf sensor, or bypass it. .:FFS TechNet : CKF Bypass Trick :.
JackAcc
Transmission & Drivetrain
Mar 17, 2012 05:02 PM
yaba3800
Sep 14, 2008 02:57 PM
DelSol808
Aug 3, 2002 05:32 PM
