will bad oxygen sensor cause sputtering when giving gas?
i just re-did the timing on dohc zc engine. it seems to be running smooth.. i can rev it lightly, but if i really press it, it spits pops and sputters. any input i am pretty sure timing is exact on. thank you for input.
Could be air pockets in your coolant.
The ecu has a sensor that sends a signal to it so judging by the temp it will know how much fuel to give.
But it can be the o2 sensor too. As well as ,any things.
i am getting code 1 and 9 i will try to bleed cooling system today see if that works. i am pretty sure timing is dead on.
oxygen code 1 and code 9 no. 1 cylinder position ... the thing in front of the distributor on zc idk what is called but is a sensor i do not believe it is hooked up right.
lizoyd18
Oct 23, 2007 02:35 PM
White91EF
May 23, 2007 10:23 PM
ScottEK
Oct 2, 2002 09:30 AM
