Obdo to obd1 probs
Old Apr 11, 2016 | 02:08 PM
Efcivic701's Avatar
Default Obdo to obd1 probs
Ef hatch obdo b18 cel for iac. Runs fine
Switch to obd1 throws same cel and put into limp mode.
Tried different ecus and different dizzys. Would the iac put it into limp mode.
Thanks for any help
Old Apr 12, 2016 | 09:04 AM
kp's Avatar
kp
Default Re: Obdo to obd1 probs
The IACV has nothing to do with the distributor, it's the unit on the intake manifold that helps regulate idle. Do you not have it hooked up?
Old Apr 12, 2016 | 03:12 PM
Efcivic701's Avatar
Yes it is hooked up. Just in limp mode
Old Apr 14, 2016 | 10:27 PM
crx_si-r's Avatar
i had the same issue in my old 98 ex. swapped iac 4 times with brand new units and issue still stayed. used a better scan tool and found out temp reading between sensor output and ecu readings were off. swapped coolant temp sensor, fan switch and cooltant temp switch. then cel went away. try swapping those out.
Old Apr 16, 2016 | 04:34 AM
Efcivic701's Avatar
That made you car in limp mode?
myefhasaname
Mar 17, 2013 10:37 PM
jesiaczek
Feb 23, 2012 06:01 PM
crxfreak1117
Sep 2, 2007 02:24 PM
JBirch_97Prelude
May 5, 2007 11:34 AM
ylfotevoli
Nov 5, 2006 01:35 PM
