97 Civic LX - idle issue
I have an issue with my 97 Honda Civic, when idling the Rpms fluctuate up and down about 1000 and when driving it seems to try and stall on its own and the temperature gauge has stopped working. Any ideas would be greatly appreciated
Stock Civic? What trim?
Pull the CEL codes and post them.
https://honda-tech.com/honda-civic-d...lists-1901557/
I changed the speed sensor iacv clutch master/slave cylinder and took out the cruise control. But yesterday when I changed the iacv I realized it doesn't have Egr in it
It has the dump off valve for it and what looks like the hose and connector that go into it
Post pics. What's the block code? It should be D16Y7, if stock.
https://honda-tech.com/honda-civic-d.../#post48684945
Have u try spraying carb cleaner around the manifold to look for a leak? Engine should be cold while u do this, risk of fire.
Then try the smoke method, see if u can spot any leak.
On the intake manifold, port where your brake booster line hook into.
Use CIG or cigar if u d9nt have a smoke machine. Pretty easy, there are couple YouTube vids on how to do it.
