Progress cs2 coilovers, am I tuning them correctly, they seem way too low? (photos)
Old Apr 10, 2016 | 07:18 AM
safedriver's Avatar
Default Progress cs2 coilovers, am I tuning them correctly, they seem way too low? (photos)
Question: After I tuned the PCS2's, did I over load the coils?
I found the solution on youtube.
Old Apr 11, 2016 | 05:36 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Progress cs2 coilovers, am I tuning them correctly, they seem way too low? (phot
What's happening here?
Old Apr 11, 2016 | 05:54 AM
safedriver's Avatar
I had maxed out one of my corners, to get the height right.
The opposing needed to be 1/2 way maxed out.
I had to undo the worst one first, then the same for the 1/2 maxed coil.
Old Apr 13, 2016 | 08:48 AM
REPTAR's Avatar
something is terribly off with your car if the height adjustments had to be that far off from each other on the coils for your car to be level. fronts should be relatively close to each other as far as adjustment goes, and the rears should be as well.
Old Apr 14, 2016 | 07:56 PM
safedriver's Avatar
I had the sequence wrong.
With all coils loaded per instructions, my Rear Left was 1/2" shorter/lower than my rear right.
At 1/16" per turn, I loaded it 9 turns the (RL) CW and that made the rears even, but the opposite front coil (FR) became too high. That's the one (FR) that I maxed out.
The problem was my sequence. I should not have tried to raise the rear left 1/2", I should have lowered my rear right (RR).
I found this out on youtube.
Anyway, none are more than a few turns, from the pre-load instructions.
ep3man
Jun 6, 2008 05:11 PM
thatbluecrx
13
Aug 5, 2005 11:50 PM
dukers
May 7, 2005 10:00 AM
