96 Civic D16Y7 Idle issue
Old Apr 9, 2016 | 10:22 AM
Ahmoody03's Avatar
Default 96 Civic D16Y7 Idle issue
I have a 96 civic 5 speed with a d16y7 its had idle issues a while and didn't occur until the ignition coil went out and wouldn't crank it sputters really bad and since the idle issue has occurred I've replaced the ignition coil the fuel pump the battery the spark plugs and wires the ignition control module and the distributor rotor button and cap and nothing has made it any better.. It only occurs when it's cold outside lk below 50 and clears up after idling a while below is a video of the car idling after start on a cold day
Old Apr 9, 2016 | 12:30 PM
Txdragon's Avatar
Default Re: 96 Civic D16Y7 Idle issue
check your coolant temp sensor
Old Apr 9, 2016 | 08:01 PM
Former User's Avatar
In the video, are you pressing the gas pedal to rev the engine?
Old Apr 10, 2016 | 09:18 PM
Bently_Coop's Avatar
Steve at Heart
After replacing the ignition parts did you check and set ignition timing with a light?
Old Apr 24, 2016 | 10:01 PM
Ahmoody03's Avatar
Will do will post info after I check it
Ahmoody03's Avatar
Yea all the way down
Ahmoody03's Avatar
No
Old Apr 25, 2016 | 04:10 AM
You don't have an idle problem. As Bently mentioned, do a full ignition system tune up (plugs, wires, cap, rotor).
Also pull the CEL codes.
mimog3
Nov 21, 2012 07:28 PM
bizmackus
Jan 23, 2007 06:01 PM
ram0869
Sep 16, 2004 12:32 PM
VDoP-B18C1
May 19, 2004 05:59 PM
MintFlavored
Nov 11, 2002 12:28 PM
