Idle Surge- 95 Accord
Old Apr 9, 2016 | 12:52 AM
ArrowCD5's Avatar
Default Idle Surge- 95 Accord
Hey guys, so I've recently tried fixing the idle surge on my CD5 and have ran into no luck. I've cleaned out the IAC and the FITV. The car wouldn't surge for about 4 hours and then would just randomly start up again. I heard getting a new map sensor might fix it but I'm unsure of how to reset the ECU. Any possible solutions you guys can offer would be awesome!
Old Apr 9, 2016 | 03:04 AM
holmesnmanny's Avatar
Default Re: Idle Surge- 95 Accord
Idle surges are simply caused by a vacuum leak. Replacing parts won't fix the problem. What you need to do is to find the vacuum leak and fix it.
It could be a leaking vacuum hose, a leaking intake manifold gasket, leaking brake booster hose etc etc.
I very fine mist of water vapor will help you find it when you hit it with the car idling.
Old Apr 9, 2016 | 04:50 AM
dh1212's Avatar
Or propane works too.
Turn it on (don't light it)
Then go around the engine intake, and vacuum lines. When the idle changes you found it.
Dannyboy94
Feb 20, 2015 09:26 PM
PROJECT 91
Sep 25, 2009 11:18 AM
93SiPrelude
Feb 24, 2008 10:39 PM
Jspeedrifter
Sep 11, 2007 12:36 PM
95 integra
Apr 12, 2004 12:08 AM
