2006 civic Sedan Camber kit
hello, just purchased a 2006 LX sedan for a daily drvier, so far it has been a great car minus the fact that the rear needs a camber kit, you guy recommend any specific manufactures? thanks
If it needs a camber kit and the car is stock it's likely something is bent. I would inspect and try to find whatever is bent and replace that instead of going the camber kit route right off the bat.
I believe there was a recall for the rear camber issue? Might want to check that out.
And I agree holmesnmanny if you are stock you don't really need a camber kit and if you aren't doing any form of spirited driving either.
thanks will look into it tomorrow after work, yes the car is stock but did read there were a lot of cars same model and year with rear tire wear......
