Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
LH slide door not working correctly .
Old Apr 4, 2016 | 11:59 AM
Tle111's Avatar
Default LH slide door not working correctly .
hello Everyone .
I have a 2005 Honda Odyssey and the driver side slide door does not function correctly . it's stop working , slide door light on dash . I'd the reset procedure it will work for two / three day and the error come back and I have to reset is again so I am getting tired of it , is anyone on here experience the same issued and is there a solution/fix for it ? I need to know if it's the control unit , the motor or some thing else because I do not want to buy the wrong parts for problem I have encounter .
Thank you everyone in advance .
Old Apr 15, 2016 | 09:10 PM
FondenR's Avatar
Default Re: LH slide door not working correctly .
While I do not own an Odyssey (I have a Pilot), I do own a 2001 Ford Windstar van that makes use of the same general sliding door contact system where the sliding door has the spring-loaded contacts that physically touch (make contact) with the door jam post contacts when closed. In the past, my electric sliding door lock on one of the doors just stopped working and I found that the tips of the spring-loaded contacts appeared to be coated with some dirt/grease/corrosion. As a wild guess, I used a small piece of sandpaper and gently cleaned off the tips of the spring-loaded contacts and the contact areas on the door jam to make sure they were making a good electrical connection. Once I had cleaned them and closed the door, my electric door locks worked perfectly from then on.
I would recommend giving this a try to see if it will work for you. Hopefully, this will work for your situation.
Best wishes,
Ron
Mychal71
Mar 20, 2022 01:32 PM
draladriver
Feb 1, 2014 01:55 PM
m.glisson003
Aug 7, 2011 12:36 PM
suhteevin
Jan 6, 2009 09:04 PM
tegpilot007
Oct 25, 2005 05:16 PM
