n00b question...
Old Nov 7, 2002 | 05:19 AM
Nate B's Avatar
Default n00b question...
I haven't had a good chance to look yet, but I need to adjust my fuel pressure regulator down a tad, it was reading 50 psi at idle this morning with the vaccum line on. Now I know to adjust the pressure correctly, the vaccum line needs to be disconnected. My question is, does the vaccum line just slide on and off of a barb? Or are there any clamps holding it in place? Also, factory settings should 38psi correct? Which means with my mods and v-afc tuning I could probably run it to about 40-42 psi without running too rich? Thanks guys.....
Old Nov 7, 2002 | 05:25 AM
Ricky Rojales's Avatar
Default Re: n00b question... (TypeR#1111)
You've been here on record for 169 days... your pulling our leg right? I think I'm the newb.
It pulls right off, but be careful that you don't rip it... otherwise just cut it down and slip it back on after you've adjusted the pressure.
[Modified by P, 9:25 AM 11/7/2002]
Old Nov 7, 2002 | 05:27 AM
sackdz's Avatar
Well normally its just barbed, but if it also has a hose clamp, you better take it to a a shop!
Old Nov 7, 2002 | 05:42 AM
Nate B's Avatar
Default Re: n00b question... (sackdz)
Old Nov 7, 2002 | 06:38 AM
Chris N's Avatar
Default Re: n00b question... (P)
Just because nate has been here 169 days doesn't mean he knows anything.
Did you search, n00b??
Old Nov 7, 2002 | 06:43 AM
Nate B's Avatar
Default Re: n00b question... (1107)
I searched fo shizzle and didn't find nizzle on the hizzle.
Old Nov 7, 2002 | 07:01 AM
Oh yeah, you need gas in the gas tank to do this mod too.
Old Nov 7, 2002 | 07:02 AM
Nate B's Avatar
sackdz's Avatar
Cigarette smoking recommended but not required.
Nate B's Avatar
Old Nov 7, 2002 | 07:03 AM
Gong Show's Avatar
hahaha, Nate the Great
Old Nov 7, 2002 | 07:04 AM
Nate B's Avatar
Default Re: n00b question... (GONG SHOW)
das my muthafuggin name y0!
Old Nov 7, 2002 | 12:48 PM
Spoon97R's Avatar
ah i'll try to help out the best i can
vacuum line slides on and off, there shouldnt be a clamp. if we're talking about the line that connects to the fpr of course.
ha, i had the damn same problem! i just asked and searched and it seems 38psi is correct, but i heard 42 was stock for itr ;p, and if you were running rich, you'll see signs of it, black smoke, CE light, worst yet, blown rattle the cattle catalytic converter.
PS. Not sure what mods your talking since you dont mention them, but with v-afc you better know what your doing
Old Nov 7, 2002 | 12:51 PM
sgT's Avatar
sgT
Default Re: n00b question... (Spoon97R)
49-54 off vacuum
Jan 5, 2005 12:20 PM
UNVMYR
Dec 23, 2002 03:07 PM
Phat_GSR
Sep 14, 2002 08:31 AM
macdaddy
Apr 26, 2002 08:58 AM
micrew
Nov 13, 2001 03:05 PM
