Honda CR-V & Element 2WD & 4WD Element & CR-V
Roof Rack Baskets? How did you install yours?
Old Apr 1, 2016 | 01:39 PM
Blanco'03's Avatar
Default Roof Rack Baskets? How did you install yours?
Ok, So I bought this used Curt Roof basket & then went to put it on my 2003 CR-V & the there seems to be no way to line it up to actually use the clamps in the kit to hold it down?
Have you guys need to mod things some how?
I'm thinking gonna have to get creative?
If you look at the photo above you see the hole downs.
Old Apr 1, 2016 | 09:39 PM
Blanco'03's Avatar
Default Re: Roof Rack Baskets? How did you install yours?
I'm currently running a Rhino Rack & the spacing is just off, so I took one of the cross bars off and was hoping a had a narrow insert or something & it does not, so if I can't an answer on-line, I'll likely try to see if maybe drilling a hole in the plastic cross bar would solve my issue, yet I worry if it would weaken its strength, but it's not like I plan to put that much weight in the basket anyways.
Old Apr 2, 2016 | 11:47 AM
Blanco'03's Avatar
Well I just went down & mocked it all up & see that drilling is not an option either.
Old Apr 4, 2016 | 05:06 AM
JoshTheJerk's Avatar
I have a 2001 and i just attached mine to the crossbars. No issue. I mean its a little off center but nothing big.
Old Apr 5, 2016 | 02:04 PM
FATKID87's Avatar
so can you move the cross bars back and forth? i just loosen mine got it where i wanted and then tightened it all down... maybe some pictures will help where the problem is
Old Apr 11, 2016 | 07:16 AM
Blanco'03's Avatar
Does not look like I can adjust them.
Old Apr 13, 2016 | 08:36 AM
BigBerz's Avatar
Completely remove the brackets from the basket. Place the basket on the rack and see where you need the cross braces to be. Can the cross braces be relocated to different mounting points on the roof? Are those OEM roof racks? It looks like there are other plastic cover pieces that can be popped off and you could relocate the cross bar to a different point?
Edit: Just searched an it looks like you have aftermarket cross bars. The OEM ones are lower to the roof and not as thick. Might need to go back to OEM. I'm sure you could trade someone. http://www.hondapartsdeals.com/images/CRV-Roof-Rack.jpg
Berz out.
Old Apr 13, 2016 | 03:13 PM
Blanco'03's Avatar
Berz out.
Thanks , Unless there is someone in the Los Angeles area that wants to swap, I'm pretty much thinking its gonna go on the top of me Sammy?
Old Apr 13, 2016 | 03:20 PM
BigBerz's Avatar
I would call Honda and see if they will trade you for some OEM ones. Yours are probably an option that cost more so they might be willing to trade off one on the lot? I think it will look out of place on the Sammy.
Berz out.
Old Apr 13, 2016 | 04:30 PM
Blanco'03's Avatar
Berz out.
You do come up with cool ideas & I thank you.
But.... well see?
Its almost too long to look right on the Sammy, Yet, I am MUCH MORE LIMITED in the Sammy on where I can carry things.
Its currently at the shop being worked on & so once I get it back & start test fitting is how I'll decide.
But seriously do appreciate your input.
Old Apr 13, 2016 | 04:52 PM
BigBerz's Avatar
It would be worth it on the Sammy as you have the spare where regular cargo would go. Whatever you decide good luck!
Berz out.
Old Apr 13, 2016 | 06:20 PM
Blanco'03's Avatar
Berz out.
Your avatar is disturbing...
Old Apr 23, 2016 | 08:53 AM
BigBerz's Avatar
Thanks I think?
Any updates?
Berz out.
Terry36
Sep 18, 2013 07:39 PM
CIVICC2000
Mar 26, 2009 05:05 PM
fcfromhell420
Sep 14, 2007 11:21 PM
